Customising JIRA Excel Output
Microsoft Office 2000 supports Hypertext Markup Language (HTML) as a native file format, allowing Microsoft Excel to save and open HTML files as spreadsheets with all the document formatting preserved. The document can be formatted through a combination of HTML, XML and Cascading Style Sheets (CSS).
The format of the Excel output from JIRA can be modified by editing the template file searchrequest-excel-header.vm (located within src/etc/java/templates/plugins/searchrequestviews/ of your JIRA home folder). Editing this file is essentially editing a HTML template file with tables and styles.
By default the template file searchrequest-excel-header.vm should contain:
<style>
@page
mso-page-orientation:landscape;
margin:.25in .25in .5in .25in;
mso-header-margin:.5in;
mso-footer-margin:.25in;
mso-footer-data:"&R&P of &N";
mso-horizontal-page-align:center;
mso-vertical-page-align:center;
br
    mso-data-placement:same-cell;
td
    vertical-align: top;
</style>
The above formats the default excel output to have the page orientation as landscape, and multi-lined text will be kept within one cell.
Further examples are provided JIRA:below.
Microsoft Office HTML and XML Reference
Microsoft Office HTML and XML reference contains a thorough listing of available styles and details on how to use them. The reference manual is available for download from http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnoffxml/html/ofxml2k.asp
Example 1. Customising Page Setup
Excel uses CSS and @page definitions to store some page setup settings and XML to store others. Below is a sample to setup the page with the following document format respectively.
  • Set page orientation as landscape (default is portrait)
  • Set the top, right, bottom and left margins as .75in .25in .75in .25in respectively
  • Set header margin as .5in
  • Set footer margin as .4in
  • Set a custom footer displaying page number, date and time all centered.
Details of the default values, and special symbols to use for styles can be found in the Microsoft Reference Manual.
<style>
@page
mso-page-orientation: landscape;
margin:.75in .25in .75in .25in;
mso-footer-margin:.4in;
mso-footer-data:"&C Page &P of &N Date: &D Time: &T";
<!-- other @page styles ... -->
</style>
Example 2. Customising Cell Formatting
Both CSS and HTML are used to customise the cells. A global style that is applied to all table cells can be applied using TD definition.
<style>
TD
mso-numberformat:general;
text-align: left;
vertical-align: middle;
color:red
<!-- other TD styles ... -->
</style>
The above applies the following styles to all table cells respectively:
  • Sets the number format of all table cells as general
  • Horizontally aligns the text in the cell to the left
  • Vertically aligns the text in the cell to the middle
  • Set the text color to be red
Individual or group of cells may have other styles applied by adding a class value into the appropriate HTML tags
Was this page helpful?
Have a question about this article?
See questions about this article
Powered by Confluence and Scroll Viewport
