Developer
News and Updates
Get Support
Sign in
Get Support
Sign in
DOCUMENTATION
Cloud
Data Center
Resources
Sign in
Sign in
DOCUMENTATION
Cloud
Data Center
Resources
Sign in
Forge modules
Automation modules
Bitbucket modules
Compass modules
Confluence modules
Dashboard modules (EAP)
Jira modules
Jira Service Management modules
Jira Software modules
Rovo modules
Teamwork Graph modules
Last updated Jan 13, 2026
Jira issue view background script
The jira:issueViewBackgroundScript module adds an invisible container to the Issue view page.
This makes it the perfect candidate for:
  • distributing shared data
  • making heavy calculations
  • running code without UI elements
Examples
Use the events API for communication between an issue view background script and an issue panel. Because modules may be rendered in a different order, we recommend that you handle both scenarios.
Issue view background script:
1
2
import { events } from '@forge/bridge';
// Emit the data to an already rendered issue panel
events.emit('app.data-change', 'initial-data');
// Listen to data change requests from issue panels
events.on('app.request-data', (payload) => {
  events.emit('app.data-change', 'initial-or-changed-data');
Issue panel:
1
2
// Request data in case the background script is already rendered
events.emit('app.request-data');
events.on('app.data-change', (payload) => {
  console.log('The data has changed:', payload)
Manifest
1
2
modules:
  jira:issueViewBackgroundScript:
    - key: background-t-issue-view-background-script
      resource: issueBgScriptResource
      render: native
  jira:issuePanel:
    - key: issue-background-dashboard-background-script-panel
      title: issue-panel
      viewportSize: medium
      icon: https://developer.atlassian.com/platform/forge/images/issue-panel-icon.svg
      resource: panelResource
      render: native
Properties
PropertyTypeRequiredDescription
key
string
YesA key for the module, which other modules can refer to. Must be unique within the manifest.
Regex: ^[a-zA-Z0-9_-]+$
resourcestringYesA reference to the static resources entry that your context menu app wants to display. See resources for more details.
render'native'Yes for UI KitIndicates the module uses UI Kit.
resolver{ function: string } or
{ endpoint: string }
Yes
Set the function property if you are using a hosted function module for your resolver.
Set the endpoint property if you are using Forge Remote to integrate with a remote back end.
Extension context
PropertyTypeDescription
typestringThe type of the module.
issue.idstringThe ID of the issue on which the module is rendered.
issue.keystringThe key of the issue on which the module is rendered.
issue.typestringThe type of the issue on which the module is rendered.
issue.typeIdstringThe ID of the type of the issue on which the module is rendered.
project.idstringThe ID of the project where the module is rendered.
project.keystringThe key of the project where the module is rendered.
project.typestringThe type of the project where the module is rendered.
locationstringThe full URL of the host page where this module is displayed.
Apps can receive frontend events that will notify your app when an issue has been changed. These events are triggered when an issue is updated or commented on, and are only available for Jira issue view modules.
1
2
import { events } from "@forge/bridge";
events.on("JIRA_ISSUE_CHANGED", (data) => {
  console.log("JIRA_ISSUE_CHANGED (Forge)", data);
However, if you have multiple issue view modules in your app, you should use the Jira issue view background script module or its Connect counterpart. This will give you a central place for fetching issue details, thus reducing the number of network requests and improving the user experience. Fetching issue details separately for every module would introduce unnecessary overhead and degrade performance.
Data shape
1
2
  "issueId": string,
  "projectId": string,
  "changes":[{
    "changeType": "updated" | "commented",
    "atlassianId": string
PropertyDescription
issueIdID of the issue the app is rendered on.
projectIdID of the project the issue belongs to.
changesList of issue changes
  • changeType - type of the change
    • commented - a comment has been added to the page
    • updated - the issue has been updated
  • atlassianId - ID of the user who made the change
Limitations
  • There is a delay between the moment the issue is modified and when the event is emitted. It might take up to a few seconds.
  • When the issue is modified by the user who is currently viewing it, it will not be refreshed. This is because we assume the change was made by that same user and there is no need for an update.
Rate this page:
