Developer
News and Updates
Get Support
Sign in
Get Support
Sign in
DOCUMENTATION
Cloud
Data Center
Resources
Sign in
Sign in
DOCUMENTATION
Cloud
Data Center
Resources
Sign in
Forge modules
Automation modules
Bitbucket modules
Compass modules
Confluence modules
Dashboard modules (EAP)
Jira modules
Jira Service Management modules
Jira Software modules
Rovo modules
Teamwork Graph modules
Last updated Feb 19, 2026
Jira issue panel
The jira:issuePanel module adds an issue panel to a Jira issue when a configured button is clicked. The content of the module is shown above the Activity panel on a Jira issue.
This module can be used in Jira and Jira Service Management. It works in the new issue view but not the old issue view.
Example of an Issue panel
Manifest example
1
2
modules:
  jira:issuePanel:
    - key: hello-world-issue-panel
      resource: main
      resolver:
        function: resolver
      render: native
      title: Hello World!
      icon: https://developer.atlassian.com/platform/forge/images/icons/issue-panel-icon.svg
Properties
PropertyTypeRequiredDescription
key
string
Yes
A key for the module, which other modules can refer to. Must be unique within the manifest.
Regex: ^[a-zA-Z0-9_-]+$
resourcestringIf using Custom UI or modern versions of UI KitThe key of a static resources entry that your module will display. See resources for more details.
render'native'If using modern versions of UI KitIndicates the module uses UI Kit.
resolver{ function: string } or
{ endpoint: string }
Set the function property if you are using a hosted function module for your resolver.
Set the endpoint property if you are using Forge Remote to integrate with a remote back end.
viewportSize'small', 'medium', 'large' or 'xlarge'The display size of resource. Can only be set if the module is using the resource property. Remove this property to enable automatic resizing of the module.
titlestring or i18n objectYes
The title of the issue panel, which is displayed above the panel. The title also appears in the ••• menu that’s clicked to display the issue panel.
The i18n object allows for translation. See i18n object.
iconstringYes
The icon that will be displayed as a button. When the button is clicked, an issue panel is added to the issue view.
For Custom UI and UI Kit apps, the icon property accepts a relative path from a declared resource. Alternatively, you can also use an absolute URL to a self-hosted icon. See Icons for more information.
If no icon is provided, or if there's an issue preventing the icon from loading, a generic app icon will be displayed.
allowMultiple
boolean
Controls whether or not multiple instances of the issue panel are shown when clicking the issue panel button repeatedly. Defaults to false.
If set to true, a maximum number of five instances of the issue panel can be shown on the issue.
displayConditionsobjectThe object that defines whether or not a module is displayed in the UI of the app. See display conditions.
i18n object
KeyTypeRequiredDescription
i18nstringYesA key referencing a translated string in the translation files. For more details, see Translations.
Extension data
UI Kit and Custom UI
Use the useProductContext hook to access the extension context in UI Kit or getContext bridge method in Custom UI.
PropertyTypeDescription
typestringThe type of the module.
issue.idstringThe id of the issue on which the module is rendered.
issue.keystringThe key of the issue on which the module is rendered.
issue.typestringThe type of the issue on which the module is rendered.
issue.typeIdstringThe id of the type of the issue on which the module is rendered.
project.idstringThe id of the project where the module is rendered.
project.keystringThe key of the project where the module is rendered.
project.typestringThe type of the project where the module is rendered.
isNewToIssuebooleanDefines if the panel was just added to the issue.
locationstringThe full URL of the host page where this module is displayed.
Extension context
Platform context
PropertyType/valueDescription
issueIdstringThe ID of the issue on which the module is rendered.
issueKeystringThe key of the issue on which the module is rendered.
issueTypestringThe type of the issue on which the module is rendered.
issueTypeIdstringThe ID of the type of the issue on which the module is rendered.
projectIdstringThe ID of the project where the module is rendered.
projectKeystringThe key of the project where the module is rendered.
projectTypestringThe type of the project where which the module is rendered.
Dynamic module (EAP)
This module can also be declared as a dynamic module. However, this capability is currently only available as part of Forge’s Early Access Program (EAP).
For more details, see Dynamic Modules.
Code examples
The following examples show Dynamic Module implementations specific to this module. For more detailed information about the API used in these examples (including error handling information), see Dynamic Modules API.
Create a dynamic issue panel module
1
2
import { requestAtlassian } from "@forge/api";
const payload = {
  "type": "jira:issuePanel",
  "key": "issue-panel",
  "data": {
    "icon": "https://developer.atlassian.com/platform/forge/images/icons/issue-panel-icon.svg",
    "resolver": {
      "function": "resolver"
    "resource": "main",
    "render": "native",
    "title": "Issue Panel"
const response = await requestAtlassian(`/forge/installation/v1/dynamic/module/`, {
  headers: {
    'Content-Type': 'application/json'
  method: 'POST',
  body: JSON.stringify(payload),
const body = await response.text();
console.log(`Response: ${response.status} ${body}`);
Update a dynamic issue panel module
1
2
const key = "issue-panel";
const payload = {
  "data": {
    "resolver": {
    "resource": "main",
    "render": "native",
const response = await requestAtlassian(`/forge/installation/v1/dynamic/module/${key}`, {
  headers: {
  method: 'PUT',
Apps can receive frontend events that will notify your app when an issue has been changed. These events are triggered when an issue is updated or commented on, and are only available for Jira issue view modules.
1
2
import { events } from "@forge/bridge";
events.on("JIRA_ISSUE_CHANGED", (data) => {
  console.log("JIRA_ISSUE_CHANGED (Forge)", data);
However, if you have multiple issue view modules in your app, you should use the Jira issue view background script module or its Connect counterpart. This will give you a central place for fetching issue details, thus reducing the number of network requests and improving the user experience. Fetching issue details separately for every module would introduce unnecessary overhead and degrade performance.
Data shape
1
2
  "issueId": string,
  "projectId": string,
  "changes":[{
    "changeType": "updated" | "commented",
    "atlassianId": string
PropertyDescription
issueIdID of the issue the app is rendered on.
projectIdID of the project the issue belongs to.
changesList of issue changes
  • changeType - type of the change
    • commented - a comment has been added to the page
    • updated - the issue has been updated
  • atlassianId - ID of the user who made the change
Limitations
  • There is a delay between the moment the issue is modified and when the event is emitted. It might take up to a few seconds.
  • When the issue is modified by the user who is currently viewing it, it will not be refreshed. This is because we assume the change was made by that same user and there is no need for an update.
Rate this page:
